×i am looking for a way to easily link the issue from another server.
we have service desk (sd) and JIRA software (project issues) on 2 different servers.
when trying to link a sd issue to a project issue from the edit screen, select link, it takes you the "issues selector" which only gives options for recent search or filter. there is no option to select a server.
image2017-1-18 11:3:4.png
from the summary screen, if there is already a linked issue, there is a visible section for linked issues, if you select the + it takes you the "link" screen which gives an option to select the server
image2017-1-18 11:4:1.png
Link can be found under "More" from the summary screen
