Hi community
I use "html for jira" in my dashboards. when I change a code, than I have to modify all of my dashboards.
Is there a possibility to integrate one gadget (template) in more dashboards by referencing?
thanks
ronald
No. A gadget on a dashboard is specific to the dashboard, they're not shared objects.
There is a welcome gadget which has a global config, so it always gives the same text when it is placed on a dashboard, but that's because it is coded to look at a system-wide block of configuration.
