openDatePicker throws error when opening
André Miguel Pereira Rodrigues
When i try to open a date picker using the following javascript API function:
https://developer.atlassian.com/cloud/jira/platform/jsapi/jira/#openDatePicker
An error occurs in the console and the picker doesn't open.
This only appears to happen in the new Jira Issue View. Has anyone else experienced this and if so did you manage to fix the problem?
Mateusz Szerszyński
July 11, 2019
Hello @André Miguel Pereira Rodrigues
problem that you mentioned was caused by a bug in Jira and it should be resolved by now. Can you check one more time and confirm that it was fixed?
Mateusz
Hi @Mateusz Szerszyński
I confirm that the bug is fixed.
Thank you,
André Rodrigues
Like Dario B likes this
Dario B
June 20, 2019
Hello @André Miguel Pereira Rodrigues ,
The exact same behavior has been previously been reported in the  below Atlassian Connect ticket: https://ecosystem.atlassian.net/browse/ACJIRA-1216
However, that ticket was solved long time ago, and I can also see that you already opened a development help request with the ecosystem team and that @Anne Calantog is already helping you in there: https://ecosystem.atlassian.net/browse/DEVHELP-2945
Please answer to the last comment in DEVHELP-2945 and, if possible, once the issue is solved paste the resolution in here so that it will be available to other users as well.
Dario
Help us plant more trees
