opsbar-sequence order not changed in workflow
ibm_kustagi_mercedes-benz_com
   As per the user requirement , I have set the order of transition from 0 to 8 accordingly.
For example On Hold set as 0. In Design as 1 .Please let me know if this correct sequence.
4 votes
Philipp Sendek
Hi @ibm_kustagi_mercedes-benz_com
welcome to the Community!
Could you please share a screenshot of the configuration where you set the obsbar-sequence property?
It is important that you define an opsbar-sequence value for all of them otherwise the sorting will be:
  • Always show transitions with the opsbar-sequence property first according to their opsbar-sequence value (lower values appear first)
  • Then show remaining transitions ordered first by category (Todo, In Progress, Done)
  • Within category order alphabetically by name of the status being transitioned to
(Source: https://jira.atlassian.com/browse/JRACLOUD-70702)
On your example, I would set the following values for the opsbar-sequence (using steps ot 10 allows more flexibility, when you want to move a transition between two others):
 Transition  opsbar-sequence
 On-Hold 10
 Ready for Development (Migrated)  20
 Ready for Testing (Migrated)  30
 Deploying to Int  40
 Designed (Migrated)  50
 In Design  60
 In Development  70
 In Test  80
 Cancelled 90
Done 100
I hope this helps.
Greetings
Philipp
Hi Philipp,
Philipp Sendek
thank you for the screenshot. It looks like you've added the opsbar-sequence property in the Status / Step, but you need to set it as property in the transitions going out of the status for which you want to set the order.
Once this is done, the order should be applied properly.
Greetings
Philipp
Hi Philipp,
   Thank you for the quick assistance, able to achieve it now ..
Like • John Funk likes this
