I am trying to upgrade JIRA from 6.4.12 to JIRA 7.1.0. I disabled all the plugins other than the ones which are compatible with 6.4.12 and 7.1.0 too.
While upgrading Jira, I am getting following errors:
2016-06-02 12:59:17,467 FelixDispatchQueue ERROR [c.a.p.o.container.felix.FelixOsgiContainerManager] Framework error in bundle com.atlassian.plugin.automation.jira-automation-spi
org.osgi.framework.BundleException: Unresolved constraint in bundle com.atlassian.plugin.automation.jira-automation-spi [126]: Unable to resolve 126.0: missing requirement [126.0] osgi.wiring.package; (osgi.wiring.package=org.quartz)
2016-06-02 12:59:17,837 FelixDispatchQueue ERROR [c.a.p.o.container.felix.FelixOsgiContainerManager] Framework error in bundle com.keplerrominfo.jira.plugins.jjupin
org.osgi.framework.BundleException: Unresolved constraint in bundle com.keplerrominfo.jira.plugins.jjupin [187]: Unable to resolve 187.0: missing requirement [187.0] osgi.wiring.package; (osgi.wiring.package=com.atlassian.jira.rpc.auth)
2016-06-02 12:59:17,886 FelixDispatchQueue ERROR [c.a.p.o.container.felix.FelixOsgiContainerManager] Framework error in bundle com.col.plugins.epic-hierarchy
org.osgi.framework.BundleException: Unresolved constraint in bundle com.col.plugins.epic-hierarchy [182]: Unable to resolve 182.0: missing requirement [182.0] osgi.wiring.package; (&(osgi.wiring.package=com.atlassian.sal.api.pluginsettings)(version>=2.0.0)(!(version>=3.0.0)))
2016-06-02 12:59:18,018 FelixDispatchQueue ERROR [c.a.p.o.container.felix.FelixOsgiContainerManager] Framework error in bundle com.atlassian.plugin.automation.automation-module
org.osgi.framework.BundleException: Unresolved constraint in bundle com.atlassian.plugin.automation.automation-module [124]: Unable to resolve 124.0: missing requirement [124.0] osgi.wiring.package; (&(osgi.wiring.package=com.atlassian.plugin.automation.spi.build)(version>=1.5.9)) [caused by: Unable to resolve 126.0: missing requirement [126.0] osgi.wiring.package; (osgi.wiring.package=org.quartz)]
2016-06-02 12:59:18,474 FelixDispatchQueue ERROR [c.a.p.o.container.felix.FelixOsgiContainerManager] Framework error in bundle com.atlassian.plugin.automation.jira-automation-plugin
org.osgi.framework.BundleException: Unresolved constraint in bundle com.atlassian.plugin.automation.jira-automation-plugin [125]: Unable to resolve 125.0: missing requirement [125.0] osgi.wiring.package; (&(osgi.wiring.package=com.atlassian.plugin.automation.core)(version>=1.5.9)) [caused by: Unable to resolve 124.0: missing requirement [124.0] osgi.wiring.package; (&(osgi.wiring.package=com.atlassian.plugin.automation.spi.build)(version>=1.5.9)) [caused by: Unable to resolve 126.0: missing requirement [126.0] osgi.wiring.package; (osgi.wiring.package=org.quartz)]]
2016-06-02 12:59:18,540 JIRA-Bootstrap ERROR [c.a.jira.event.DefaultListenerManager] Could not configure listener:*** comment Auto-Transition className:com.atlassian.jira.toolkit.listener.AutoTransitionListener
com.atlassian.jira.event.ListenerException: Could not find class: com.atlassian.jira.toolkit.listener.AutoTransitionListener
Caused by: java.lang.ClassNotFoundException: Class 'com.atlassian.jira.toolkit.listener.AutoTransitionListener' not found.
2016-06-02 12:59:18,566 FelixDispatchQueue ERROR [c.a.p.o.container.felix.FelixOsgiContainerManager] Framework error in bundle com.atlassian.plugin.automation.jira-automation-spi
As per earlier posts,
I have tried deleting contents from .osgi-plugins and .bundled-plugins, but no luck.
any help is appreciated. I can attach logs if thats more useful.
Mansi
8.8.0 same error
So, no answer here ? No one found the cause/solution for this ?
Still happening.
got the same error upgrading from JIRA 6.3.10 to JIRA 7.2.3 :
2016-10-28 15:14:07,458 FelixDispatchQueue ERROR [c.a.p.o.container.felix.FelixOsgiContainerManager] Framework error in bundle com.atlassian.plugin.automa tion.jira-automation-spi org.osgi.framework.BundleException: Unresolved constraint in bundle com.atlassian.plugin.automation.jira-automation-spi [126]: Unable to resolve 126.0: missing requirement [126.0] osgi.wiring.package; (osgi.wiring.package=org.quartz) at org.apache.felix.framework.Felix.resolveBundleRevision(Felix.java:3974) at org.apache.felix.framework.Felix.loadBundleClass(Felix.java:1824) at org.apache.felix.framework.BundleImpl.loadClass(BundleImpl.java:937) at com.atlassian.plugin.osgi.util.BundleClassLoaderAccessor$BundleClassLoader.findClass(BundleClassLoaderAccessor.java:66) at java.lang.ClassLoader.loadClass(ClassLoader.java:424) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at com.atlassian.jira.plugin.DefaultComponentClassManager.constructEvenIfNotEnabled(DefaultComponentClassManager.java:104) at com.atlassian.jira.plugin.DefaultComponentClassManager.newInstance(DefaultComponentClassManager.java:57) at com.atlassian.jira.service.OfBizServiceConfigStore.loadServiceClass(OfBizServiceConfigStore.java:322) at com.atlassian.jira.service.OfBizServiceConfigStore.instantiateServiceContainer(OfBizServiceConfigStore.java:213) at com.atlassian.jira.service.OfBizServiceConfigStore.getServiceContainer(OfBizServiceConfigStore.java:186) at com.atlassian.jira.service.OfBizServiceConfigStore.getAllServiceConfigs(OfBizServiceConfigStore.java:174) at com.atlassian.jira.service.DefaultServiceManager.loadServiceCache(DefaultServiceManager.java:581) at com.atlassian.cache.memory.MemoryCacheManager$1$1.load(MemoryCacheManager.java:93) at com.atlassian.cache.memory.MemoryCacheManager$1$1.load(MemoryCacheManager.java:69) at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527) at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319) at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282) at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197) at com.google.common.cache.LocalCache.get(LocalCache.java:3937) at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941) at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824) at com.google.common.cache.LocalCache$LocalLoadingCache.getUnchecked(LocalCache.java:4830)
