According do the documentation it if a good idea to perform a full re-index once in a while, say once every two months.
But typically this can only be performed when the system is not needed. This would ideally happen at the weekends in the evening. As no-one wants to open the Work Laptop to click full re-index, is it possible to automate it somehow? maybe with script runner?
I have searched and I do not see anythig for this, only for re-indexing issues in Projects, and not for the configuration.
I would not recommend trying to script re-indexing. I see you are on Server, so for now on your version one part of it is something could go wrong and you would want to make sure you have someone on call for it, thus having that person click the button is the way to go.
If you choose to stay locally hosted and not move to Cloud by 2024, then with data center it supports multiple nodes with zero down time. However, you need to take one node offline and sync it back up.
It is possible to automate through something like Ansible but I would recommend considering which path (Cloud versus Data Center) you plan on going with before investing time in automation of re-indexing as well as reporting you will need in case it fails.
Best,
Clark
Many thanks for the answer.
I had considered indexing to be a benign thing to do, and did wonder why there was no automation. This makes sense.
I have seen there a list of issues to look out for when performing re-index.
https://confluence.atlassian.com/jirakb/troubleshoot-index-problems-in-jira-server-203394752.html
Out of interest, how has your personal experience been with full re-indexing?
Can you provide some estimates of when to perform this.
This is a brief summary of our Server (I am not sure what relevant information is useful):
Users 1600
Projects: 371 (of which around 220 are considered active)
I have developed a ScriptRunner script that starts a background reindex using the reindex REST APIs. The script can then be set up as a SR job that runs e.g. once a week.
For a full reindex just replace the type=BACKGROUND_PREFERRED with type=FOREGROUND
Hope it helps.
* Start Jira reindex through a REST API call
* The script first verifies that there is no other reindex running
import com.atlassian.sal.api.ApplicationProperties
import com.atlassian.sal.api.UrlMode
import com.atlassian.sal.api.net.Request
import com.atlassian.sal.api.net.TrustedRequestFactory
import com.onresolve.scriptrunner.runner.customisers.PluginModule
import groovy.json.JsonSlurper
import groovyx.net.http.URIBuilder
@PluginModule
TrustedRequestFactory trustedRequestFactory
@PluginModule
ApplicationProperties applicationProperties
final reindexAPI = '/rest/api/2/reindex?type=BACKGROUND_PREFERRED'
final reindexStatusAPI = '/rest/api/2/reindex/progress'
def urlIndexStatus = applicationProperties.getBaseUrl(UrlMode.CANONICAL) + reindexStatusAPI
def urlStartIndex = applicationProperties.getBaseUrl(UrlMode.CANONICAL) + reindexAPI
def requestIndexStatus = trustedRequestFactory.createTrustedRequest(Request.MethodType.GET, urlIndexStatus)
def requestStartIndex = trustedRequestFactory.createTrustedRequest(Request.MethodType.POST, urlStartIndex)
def host = new URIBuilder(urlIndexStatus).host
log.info("Host: " + host)
def indexRunning = false
try {
requestIndexStatus.addTrustedTokenAuthentication(host)
def responseBody = requestIndexStatus.execute()
def responseAsMap = new JsonSlurper().parseText(responseBody) as Map
if( (int) responseAsMap['currentProgress'] < 100){
log.info("Index in progress. Percentage complete: "+ responseAsMap['currentProgress'])
indexRunning = true
}catch(def error){
log.info("No index running")
if( !indexRunning ){
log.info("No reindex in progress. Attempt to start a new reindex")
try {
requestStartIndex.addTrustedTokenAuthentication(host)
def responseBody = requestStartIndex.execute()
log.info("Index started")
log.info(responseAsMap)
}catch(def error){
log.info("Reindex not started. " + error)
}else{
log.info("NO new reindex started")
Hello @VF ,
Maybe you can help with Jakob error? Comment bellow. Maybe you know from the experience the root cause of that 411 error.
It looks like the API calls are failing. And the explanation I could find in atlassian community is that this could be a proxy problem solvable by setting the content length of the call to 0. Please read more here:
https://community.atlassian.com/t5/Jira-questions/411-error-while-trying-to-POST-to-an-api/qaq-p/1064740
So what you could try is set an empty body to the request. For example by adding the following line right below line 58 requestStartIndex.addTrustedTokenAuthentication(host) :
requestStartIndex.setRequestBody("")
However I can not test if this works as I can not reproduce the error on our servers. Hope this helps.
Thanks for the replay.
I have changed to this, and now I get another Error code.
try {
requestStartIndex.setRequestBody("") //Added
}catch(def error){
}else{
Error that I get:
2022-06-24 13:51:41,777 INFO [runner.ScriptBindingsManager]: Host: jira.customer.com
2022-06-24 13:51:41,793 INFO [runner.ScriptBindingsManager]: No index running
2022-06-24 13:51:41,793 INFO [runner.ScriptBindingsManager]: No reindex in progress. Attempt to start a new reindex
2022-06-24 13:51:41,809 INFO [runner.ScriptBindingsManager]: Reindex not started. com.atlassian.sal.api.net.ResponseStatusException: Unexpected response received. Status code: 415
Br Jakob
Hi Jakob
Please replace the line you have just added with these 2:
These should handle the content format.
Hi
And it works :-)
I had to import the class, though.
import groovy.json.JsonBuilder //Added
Thank you for helping, it's appreciated.
Br Jakob
It could, but don't do it.
You should not have any need to re-index regularly. If you think you do, then you actually have another, deeper, problem that you need to debug and fix.
Thanks Nick. Due to regular customization we do (we're enterprise) we re-index weekly . Can you elaborate the possible problems we may encounter?
Just that the system will be unusable during re-indexing, if you're doing it properly.
Hi Nick,
I'm trying to create an email notification for indexing status. I have the code below but the while loop is not working as expected. It's just spins around. Any advice?
I would guess that your percentStatus is not being filled with a percentage number that you can usefully compare with 100.
Hi @Nic Brough -Adaptavist-
We perform an automated update to the most recent LTS version of Data Center.
Do we not need to perform a regular re-index after the updates?
How about after regular Configuration Management like deletion of projects, schemes etc (again this is automated mostly) As we always get notifications when we even just update custom field values that a re-index is required.
Can't get it to work.
Can you help?
2022-06-09 00:30:00,542 INFO [runner.ScriptBindingsManager]: Host: jira.customer.com 22022-06-09 00:30:00,637 INFO [runner.ScriptBindingsManager]: No index running 32022-06-09 00:30:00,637 INFO [runner.ScriptBindingsManager]: No reindex in progress. Attempt to start a new reindex 42022-06-09 00:30:00,668 INFO [runner.ScriptBindingsManager]: Reindex not started. com.atlassian.sal.api.net.ResponseStatusException: Unexpected response received. Status code: 411
Hi everyone,
I've created a job with all your suggestions above but it still does not work. Would you please have advise on what has to be changed. Thank you in advance:
Hello
same error for me:
2022-09-07 06:54:27,431 INFO [runner.ScriptBindingsManager]: Host: jira-uat.1place.com
2022-09-07 06:54:27,461 INFO [runner.ScriptBindingsManager]: No index running
2022-09-07 06:54:27,461 INFO [runner.ScriptBindingsManager]: No reindex in progress. Attempt to start a new reindex
2022-09-07 06:54:27,463 INFO [runner.ScriptBindingsManager]: Reindex not started. com.atlassian.sal.api.net.ResponseException: java.net.UnknownHostException: jira-uat.1place.com
Do you have an idea ?
fyi: jira server V8.20.11
Register now
