post function to transition linked issues
Debraj neogi December 2, 2015
We are trying a post function in our workflow where if an issue that blocks a linked issue is Closed, the linked issue should go to To Test status. Which exact post function can help us achieve this?
Thanks.
Nic Brough -Adaptavist-
December 2, 2015
You won't be able to do that on Cloud, it's a complex requirement that effectively needs code which you can't add to Cloud.
If you were on Server, I'd use the script-runner to get a list of links of that type, check the other ends of the links and trigger the relevant transitions on the target issues.
Help us plant more trees
