I just pulled out from archive a project.
The backlog of that project is ok.
Clicking on create task, show a loader in the project input field.
And the task can't be created.
Hi @Yaakov Aglamaz ,
After restoring a project from an archive, the system might need some time to reindex stuff in the background. That being said, the project picker for the restored project might not work instantly.
Are you still experiencing this issue? Additionally, have you tried using a different browser or incognito/private session to see if the same issue appears there?
Tobi
Thank you for your reply!
I tried working with firefox, and it work.
So GPT suggest that a chrome extension was causing the error. And indeed "Jira rtl" did it.
Writing in rtl language is very bad in Jira, no way to make the test start at the right.
Is this feature in plan?
Thanks, Yaakov.
I managed to find the following: CONFCLOUD-1373: Support RTL languages (e.g. Hebrew, Arabic, Persian) for editing and searching (although that's for Confluence). But you can try to search if there are any open suggestions for Jira but I suspect that once they start developing that for one tool, it will be designed to cover all others as well.
Tobi
