Hi, I have made a custom multi-select field in my task screen, to distinguish between task types. So most issues won't have anything selected in this field, but some will.
I want to create a JQL query on this field to return all the issues that have a selection on this multi-select field. So for example, my field is called 'workshop' and the options to choose in the drop-down are 'risk', 'design thinking' and 'compliance'.
I was thinking that the following JQL would work...
workshop = "risk" OR "design thinking" OR "compliance"
but this isn't working for me. Any suggestions?
Dear @Stu,
you JQL's syntax is wrong. You can only compare a field with a fixed value or function.
It has to be
workshop = "risk" OR workshop = "design thinking" OR workshop ="compliance"
So long
Thomas
A little bit left of the vote button (hover over). There you can set a green check.
Vote and accept are different.
Many thanks
Thomas
