"Option value 'values' is not valid" Error
francis.guibernau
February 22, 2022
Is it possible to copy multiple values of a multiselect custom field from one issue to the same field in another issue?
I am currently encountering the following error when the source customfield contains more than just one value.
My code:
Screen Shot 2022-02-22 at 20.11.24.pngIt should be noted that in the case that the source field contains just one value, the append is performed without problems.
Melo
Hi @francis.guibernau, welcome to the community!
I would use the regular "copy value from" instead of the advanced one in this scenario.
Please let me know if that helped.
Melo
Kendall Totten
Hello, unfortunately using the Copy value from one multi select field to another doesn't work.
Yong Yang
I have the same issue:
Edit issue
Error editing issues
BCM-4 (Option value ' xxx' is not valid (customfield_16189))
Issues edited successfully
BCM-4
Automation Rule: Copy a multi-select field value from the linked issue's same field:
Trigger: issue creation
Branch: For Linked issues -> create a variable to store the linked issue's Region field value
varFeatureRegion: issue.Region
Branch: For each: Smartvalue:
{{varFeatureRegion.split(",")}}
Action: Edit issue with Additional fields:
"update": {
"customfield_11238": [
"add": {"value": "{{varRegion}}"}
What's the reason why mutiple Region values cannot be copied correctly?
