"Resolution" field "NOT IN" operator is showing incorrect data in JQL
Kalpathi Rajkumar Harishma June 25, 2024
When I'm trying to give a JQL with "Resolution" as below, the tickets with "Resolution" as "Unresolved" are not capturing in the result data, could you please help to find the issue and provide the correct JQL to proceed.
JQL E.g.,
resolution NOT IN ("Duplicate", "Not a Defect", "Canceled / Rejected")
3 votes
Dexter de Vera
June 25, 2024
Hi @Kalpathi Rajkumar Harishma
Your JQL expect a value from resolution, you may add " OR resolution = Unresolved" to include also the empty / Unresolved resolution.
resolution NOT IN ("Duplicate", "Not a Defect", "Canceled / Rejected") OR resolution = Unresolved
Hope it helps!
@Dexter de Vera
It worked Thanks!
