"Story Points" field is not available for the "Issue Detail View"
Tim Padgett August 27, 2019 edited
For a new project with new scrum board, the "Story Points" field is not available for the "Issue Detail View".
EDIT:  "Story Points" seems to be available only for Kanban boards.
Randy
August 27, 2019
Story point estimate is the last item at the bottom of the list in your screenshot.
That's not "Story Points", they are two different fields.
Randy
August 27, 2019
Ah you're right.  Is Story Points available in your field configuration for the project?  Also, what do you have set for the "Estimation" section of the board configuration?
