rename status in workflow
Kamil Askerov
April 26, 2024 edited
I have 2 workflow that have same statuses expect 1 status that is different. New and Open in To Do category. How I can rename one of this statuses. When I try to rename status open to new or new to open , then
A status with that name already exists, please enter a different name
I have this message.  How to rename 1 of this status? Try to rename to other name both but not worked
John Funk
Hi Kamil,
Is this a Company-managed or Team-managed project?
And, no, you can't rename a status to the same name as an existing status.
You need to Copy the workflow you want to change. Then in the copy version of the workflow, you need to delete the current status and replace it with the other status.
Then you need to update the Workflow Scheme to change out the current workflow for the new one you created by copying.
This is all assuming it is a Company-managed project.
Kamil Askerov
Thank you @John Funk for your answer. This projects migrated from Jira not cloud version and types Service management and Company-managed software types.
John Funk
Same answer as above then.
Like Kamil Askerov likes this
Kamil Askerov
@John Funk I try to delete that status but cant do that.
Kamil Askerov
@John Funk First copy. Ok understand
Like John Funk likes this
John Funk
Answer is still the same - see above ☝️
Kamil Askerov
@John Funk and different of workflows is that 1 of them have all status -> status can change to any status. Other workflow have status ierarchy -> wich status and when can changed to wich status.
