resolution field cannot be editted
atish pradhan April 16, 2018
we want edit option for resolution field so that user can edit the resolution.
Manon Soubies-Camy
April 16, 2018 edited
Hello @atish pradhan,
Removed thanks to Nic comment
There can be different reasons why the Resolution field changes automatically:
  • If you're using a Kanban board, go the board settings and uncheck the "Set resolution" box - otherwise it will automatically be set to Done:
  • If you're not using a Kanban board, I guess the Resolution field is set using a post-function, see this page.
Hope this helps,
- Manon
Nic Brough -Adaptavist-
April 17, 2018
Create transitions from "closed" back to "closed" (or whatever your "end status" are), and give those transitions screens which include the resolution field.
Manon Soubies-Camy
Answered too quickly and didn't think of that! Thanks for the correction.
April 17, 2018
NO NO NO  -  Never put the resolution field on the edit screen.  This breaks your system because issues become closed while open.
Sarah
How do we remove it once added?  I don't seem to have it in my workflow, when i remove it from my fields it doesn't change the transition.
May 1, 2018
Create transitions that have a "clear resolution field" post function on them.
Sarah
sorry, i'm a newbie, don't quiet undertand how to do that?
Sarah
Ok i've got it now.
My other question now is,
when i change the status of my cards to 'done' they are not being crossed off as completed.  I must of missed a auto transition?  How can I do this?
May 2, 2018
To get them crossed out, you have to make the workflow set a value in the resolution field on the transition to done.  That needs a screen with the resolution on it, or a post-function to set it automatically (that's what the tick box in the original question does)
we dont want it to change automatically
