script runner question for custom fields - notification issue
Sam Rajagopal May 6, 2015
We have a custom field called 'Customer Impact'. Please note the single space between 'Customer' and 'Impact'. When this field is set, I would like to send an email to customer support organization. If you have any thoughts, please suggest. Hoping to use "script runner".
I went ahead and added a new event as follows :
system -> events -> Add New Event
Description : Customer Impact field updated
Template : Issue updated
How do I associate this event with the workflow ?
Basically, how to generate notification by watching for the status of a custom field. ?
My another question is - in our jira project screen, we have a checkbox for doc required (yes/no). If checkbox is checked, I would like to be able to send a notification to the doc team.
Thanks Jamie
JamieA
May 11, 2015
If you're not sure about your condition, test the different clauses separately. If you just want to check the text field has a value use:
cfValues['Customer Impact']
I think that is all you need.
Sam Rajagopal July 17, 2015
thanks Jamie. That works.
I chose "Send a custom email" listener, with the condition string to be -
changeItems.any {it.get('field')=='customfield_10301'} && cfValues['customfield_10301'] == 'true'
Email Template = $issue
Subject Template = customer escalation for $issue
I don't see any email coming along.. 10301 is the id for  custom field "Customer Impact" This is a text entry box where you can type in, a paragraph. So, value == "true" is reasonable ?
any clues please ?
Help us plant more trees
