script validator - custom field value
arild marthinussen September 17, 2013
Hi I wan't to add a validator to a transition. Users should not be allowed to pass transition (next status in workflow), unless customvalue field 'DeployedBy" has a value, and user should get a message saying "DeployedBy field must have a value'
I've tried adding validator on the transition
cfValues['DeployedBy'] != 'EMPTY' with errormessage "DeployedBy field must have a value"
Gives no result - pass through the transition even if deployedby is empty, or has a value - no errormsg
cfValues['DeployedBy'] == 'EMPTY' with errormessage "DeployedBy field must have a value"
Throws the errormessage every time, both when DeployedBy field is empty, or has a value
Any ideas ???
6 votes
JamieA
September 17, 2013
I feel like I should make a t-shirt saying: "What kind of field is it?"
But to check it has some value, you can just use:
You don't need to compare with the empty string... if it's empty it will be null. Use built-in scripts -> Condition Tester, and asserts (see docs).
arild marthinussen September 18, 2013
:-) , 1 mill thanks :-) - it works
RambanamP
September 17, 2013
try something like this cfValues['DeployedBy'] == ''
you can check here for script runner validator sample codes
https://jamieechlin.atlassian.net/wiki/display/GRV/Validators
another way is you can use field required validator from JSU plugin(free)
https://jsutil.atlassian.net/wiki/display/JSUTIL/JIRA+Suite+Utilities+Workflow+Validators#JIRASuiteUtilitiesWorkflowValidators-FieldsRequiredValidator
Register today
