I'm using scriptrunner to create a sub-task as a postfuction in one of my transitions.
According to https://answers.atlassian.com/questions/123997 I should be able, in the sub-task create transition, set something to tell it not to inherit the parent's field values. I am unable to find where to unset "Set Field Value from Parent". All of the parent's fields that also exist in the sub-task are getting populated with the parents values. I can live with this, but would REALLY like to clear all of the watchers out.
Here's what I have so far that's working like a charm. The question is - what do I add to it to clear the watchers from the sub-task? Thanks!
def cf = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Product Name'} issue.summary = sourceIssue.getCustomFieldValue(cf) issue.summary = issue.summary + " - License" issue.description = ""; checkLink = {link -> false};
You can use this scripted post-function to remove all watchers from an issue:
import com.atlassian.jira.component.ComponentAccessor def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser() def locale = ComponentAccessor.getLocaleManager().getLocaleFor(user) def watcherManager = ComponentAccessor.getWatcherManager() def watchers = watcherManager.getWatchers(issue, locale) watchers.each { watcher -> watcherManager.stopWatching(watcher, issue) }
I put your scripted post-function as the last post-function in the sub-task create workflow. Didn't work. I'm assuming, perhaps incorrectly, that the sub-task create transition invoked from the parent workflow executes the post-functions that exist in the sub-task create workflow. Or does it not?
I then tried putting it in the sub-task create transition in the parent workflow and received the following error:
[c.o.s.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: IS-10597, actionId: 911, file: null java.lang.NullPointerException at com.google.common.base.Preconditions.checkNotNull(Preconditions.java:210) at com.google.common.cache.LocalCache.get(LocalCache.java:3936) at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941) at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824) at com.google.common.cache.LocalCache$LocalLoadingCache.getUnchecked(LocalCache.java:4830) at com.atlassian.jira.issue.watchers.DefaultWatcherManager.getWatcherUserKeys(DefaultWatcherManager.java:159) at com.atlassian.jira.issue.watchers.DefaultWatcherManager.getWatchers(DefaultWatcherManager.java:136) at com.atlassian.jira.issue.watchers.WatcherManager$getWatchers$0.call(Unknown Source) at Script47.run(Script47.groovy:11)
The sub-task create workflow now looks like this:
def cf = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Product Name'} issue.summary = sourceIssue.getCustomFieldValue(cf) issue.summary = issue.summary + " - License" issue.description = ""; checkLink = {link -> false}; import com.atlassian.jira.component.ComponentAccessor def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser() def locale = ComponentAccessor.getLocaleManager().getLocaleFor(user) def watcherManager = ComponentAccessor.getWatcherManager() def watchers = watcherManager.getWatchers(issue, locale) watchers.each { watcher -> watcherManager.stopWatching(watcher, issue) }
To be clear, I don't want to clear the watchers from the parent issue, but from the newly created sub-task.
In the sub-task, I added a "clear watchers" transition that only calls your code and it works like a charm. It's a couple more steps (have to go into the sub-task, etc) but better than nothing!!!!
Great, glad its working for you. Yeah sticking it on the create transition for the sub-task will work.
Putting it in the create transition for the sub-task did not work. I just have a New -> New transition called "Clear Watchers" and all it does is run your script.
But it does exactly what I need. So thank you.
Hello!
i have an error in this place:
The script could not be compiled: <pre>org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script19.groovy: 6: expecting '}', found '-' @ line 6, column 25. watchers.each { watcher -> ^ 1 error </pre>.
Added a Custom script post-function (scriptrunner).
Solution: need to change ">" to ">".
Thank`s a lot to cool guys from the telegram`s chat of Atlassian Community!
