scriptrunner script Copy data from single-user picker to multi-user picker
uvo3 main public name
How to copy data from single-user picker to multi-user picker field by script runner postfunction script.
Example:
It is necessary to copy user from single-user picker field called Oneuser to add the user (if presented) to multi-user picker field called Destusers
September 8, 2023
Hi @uvo3 main public name
For your requirement, all you have to do is use ScriptRunner's Custom Script Post Function and include the working code below:-
def sampleUserPicker = issue.getCustomFieldValue('Sample User Picker')
issue.set {
setCustomFieldValue('Multi User Picker', sampleUserPicker)
Please note that the sample working code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
Please ensure you have upgraded your ScriptRunner plugin to the latest release, i.e. 8.11.0, so you will get the latest fixes and features, including ScriptRunner's HAPI
Below is a screenshot of the Post-Function configuration:-
Below are a couple of test screenshots for your reference:-
1. When the issue is first created, only the Summary, Description, and Sample User Picker (i.e. Single User Picker) fields are updated.
2. Once the issue has been created, i.e. To Do status, the value from the Single User Picker is displayed.
3. Once the issue is transitioned to In Progress, as expected, the Multi-User Picker field is updated with the value selected from the Single User Picker.
I hope this solves your question. :-)
Thank you and Kind regards,
Ram
Markus W_ BENES
Do you have a script example that isnt working?
SERVER
VERSION
8.13
