setup different custom field(drop down) options in jira issue with parent ID
Anusha Iyer January 9, 2023
Possibilities on setting up different set of options to a dropdown custom field in epic jira issue which comes under particular parent ID.
For example we have a issue as ABC-12 and 5 issues have been linked to it only those 5 issues which is linked to ABC-12 should have set of options on particular custom field.
Appreciate any type of input.
Anusha
Tessa Tuteleers
January 10, 2023 edited
Hi @Anusha Iyer ,
interesting question, I'm particularly curious for the use case you would have.
In terms of the how, I would envision it looking something like this:
  • set the field (dropdown, checkboxes,..) on the parent issue
  • when an issue is linked to that, it copies the values of the parent issue so you can use them (only) there
Did I understand correct?
I don't think something like this is possible in standard Jira, you might need to look into (a combination of) apps.
I'm sure it won't be the only possibility and I'm not an app vendor, but I would try a custom checkbox app (like this one ) and then copying the values from the parent issue to the linked issues with automation rules.
Hope this helps.
- Tessa
atlassian, rovo agent workshop, rovo workshop series, build rovo agent, atlassian intelligence, ai agents, rovo in action, automation agents, ai for teams, atlassian learning, rovo development, agent building tutorial
[Workshop Series] Let's build a Rovo Agent
AI-curious? This series walks you through building Rovo Agents step by step, no matter your experience level. Multiple workshops available throughout October and November!
Register now
Upcoming Jira Events
