show conditional textbox when any checkbox is checked from checklist
NehaNagori June 12, 2017
I have workflow screen associated with each transition. Mainly transitions have checklist.
I want a textbox, which will appear when I check any checkbox.
Nic Brough -Adaptavist-
June 12, 2017
There's no field setup in JIRA that does things like that natively, but see https://community.atlassian.com/t5/JIRA-questions/How-can-i-make-one-custom-field-depend-on-another-custom-field/qaq-p/596533 for some suggestions.
NehaNagori June 20, 2017
I have visited the link.
Can you please let me know the plugin. I have already installed Script runner. I am not able to find the solution. I am using jira6.1.
Please help me in implementing the same.
Or if there is any solution using scripts, Please let me know that also.
June 20, 2017
