You will need to go into your Board Configuration (Board >> Configure Board >> Estimation) and make sure that your Estimation Statistic is set to Story Points. This should automatically enable the Story Points to be Viewed on your board in both Backlog and Active Sprint views. You will need to be listed as a Board Administrator in order to make this change.
I have Site Admin status, but I don't see an option to set Estimation on myt Configure Board view. Is there additional access I need?
