split/parse a value return with Regex
wajih zouaoui
July 16, 2020 edited
i need to split a return value string and then create a list with it.
Like i have a returned value with ABCD-12345ABCD-67891 and i need to split this result and have a list with [ABCD-12345,ABCD-67891] using regex
def sampleText = "ABCD-12345ABCD-67891"
return sampleText.split("regex TBD")
 I need the Regex to be used in order to have the result  similar to the format shown as a list.
Thanks in advance.
brbojorque
Hi @wajih zouaoui ,
You can refer to the sample script below.
def matcher = sampleText =~ /TBD-[0-9]/
matcher.find()
if(matcher.size()){
matcher.each{
log.debug(it)
You can find how it works in real script here.
https://community.atlassian.com/t5/Jira-Software-questions/How-to-automatically-link-the-Jira-ticket-if-we-paste-Jira-link/qaq-p/1252935
SERVER
