supporting multiple workflows under a single project
Edward Geddes
I have two workflows running under a single project. Each workflow is associated with a different issue type.
These workflows are similar enough that they can share some of the same statuses (ex: In Dev, In Test). When building the workflows, I repurposed these similar statuses.
I am running into problems with my rapid boards. I'd like to have issues that are issue type bug go on rapid board a and have issues that are issue type enhancement go on rapid board b.
Is that going ot be possible with these shared statuses? (right now i get cross contamination when an issue lands in one of these statuses)
Or do I have to subtly name them different or even ru nthem under separate projects?
John Burns
September 5, 2012
You shoudl create two filters, one for each board. One filter can say type = bug and the other can say type = enhancement. Filter 1 can be used on rapid board a and filter 2 can be used on rapid board b
Edward Geddes
Thanks John! So juist to confirm, i am using jql on the saved filter to isolate which issues i want on which boards. seems to be working perfectly. (unless i misunderstood then i'm not sure what i'm doing!)
John Burns
September 6, 2012
That is correct
Learn more
