Hello
I'm looking for a solution to synchronize version between many projects without using a plugin.
when a version is created or edited in project A, it will be duplicated in B C D projects
any idea please!
Regards
Without a plugin you will have to do it manually unfortunately.
But here is as solution for you with Jira Automation: https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Automation-Create-a-version-in-another-project/qaq-p/1451018
Regards
