Hi all,
now we've installed JIRA 6.1. In the previous version when a user inserted an image in a comment automaticcally it appeared as a thumbnail. Now in this version the image attached appear as a 'large' image and you've to insert |thumbnail if you want the previous result.
There is the possibility to automatically insert all images in comment as thumbnails?
Thank you!
Simona
this problem occures again. Before when I was drag and drop image from folder to comment feild it appeard as a thumbnail link, now it's large image. How to do that it will be thumbnail link again?
Opt out of the new UI, then they'll default to |thumbnail again
we have this problem since upgrading from JIRA 7.0.x to 7.1.2
we discovered that if you put "* " before the inline thumbnail, i.e. make the thumbnail image a bullet point, then it works.
p.s. see https://answers.atlassian.com/questions/38742813
Hopefully this helps someone -
I figured out that @Paul Mansfield is correct about the need for the bulleted list but I found it difficult to achieve when in "Visual Mode"
Switch over to "Text Mode" and you'll be able to do something like this:
* !IMG_20190521_154326.jpg|thumbnail!
* !IMG_20190521_154329.jpg|thumbnail!
HTHs
It's so ugly to have huge screenshots in the comments section. Enterprise software should not require users to do such hackery to get basic functionality correct.
