trying to import Cascading Custom field values, not working. I have more than 500 values to import. added, it is only updating the first column with both column values. Please suggest
Hi @Sangram Darole , can you confirm you are importing using the import under settings - system and not using the import under the create button. Here is the documentation excerpt on this but it appears you may be following the format.
You can import values to a cascading choice custom field using the following syntax:
1
Summary, My Cascading Custom Field
2 Example Summary, Parent Value -> Child Value
The '->' separator allows you to import the hierarchy.
