Sign up Log in
kedar
Nic Brough -Adaptavist-
September 11, 2023
Hi Kedar,
What do you mean by "integrate"?  It tells us you have systems you want to talk to each other, but nothing else.
The answer to "How do I integrate" is
  • Define what you want the integration to actually do
  • Work out if it can be done natively by looking at what interfaces the applications have
  • Have a look at the marketplace to see if someone has an app that could help
We can't tell you much more than that without knowing what your integration is for
Elyes Gannoun [Elements]
September 11, 2023
Hello @kedar ,
If you are entitled to use a third-party app, let me introduce to Elements Connect, an app from my company.
With this app, you can create connected fields such as select lists directly available in your issues, with options retrieved by an API call.
You'll only need to connect to SAP API, and configure relevant queries. You can follow our documentation to understand more how you can achieve this.
If you need further assistance, our support is also available.
Let me know should you need any help!
Elyes
Alex Koxaras _Relational_
September 10, 2023
kedar
Yes I checked in marketplace but I want to know that which add:on was the best to integrate without having further issues regularly
September 11, 2023
There's no way to begin to suggest which one might suit you best without knowing what "integrate" means!
kedar
Hi Nic,
To set up the Integration in bidirectional way from Jira cloud to SAP cloud.
September 14, 2023
Repeating "integrate" does not explain it.
What do you want your "integration" to actually do?
SERVER
