update an issue field on event "issue updated"
RPO November 15, 2024 edited
I want to update a Field of an issue every time this issue is updated. To do that i am using a listener on the event "issue updated" with a little script:
def summary = event.issue.getSummary()
def type = event.issue.issueType.getName()
if (type == 'Epic') {
    event.issue.update {
      setEpicName(summary)
However i imagine this it would create an infinite trigger of the "issue updated" event, as i am updating the issue with my script either.
Is this the case? or scriptrunner's scripts do not trigger events events like "issue updated"?
setEpicName
RPO November 22, 2024
I run some tests and the answer is yes.
The command
event.issue.update {... }
will  generate a new "issue updated" trigger.
if not used correctly the issue will be updated recursively many times.
I have solved the problem with this code:
Issue issue = event.getIssue()
def type = issue.issueType.getName()
def summary = issue.getSummary()
def epicName = issue.getEpicName()
if (summary != epicName) {
issue.update {
setEventDispatchOption(EventDispatchOption.DO_NOT_DISPATCH)
setSendEmail(false)
Leonel Goitia November 15, 2024
Hi, agree with @Marc - Devoteam
you can use this trigger
I am exploring possibilities.  :)
Uladzislau Samuseu
Hi @RPO
May be you have to add a check at the beginning like "if summary is not updated".
true, i will.
but the main question is if the script triggers automatically an event when i update an issue, or not
Marc - Devoteam
November 15, 2024
Hi @RPO
Welcome to the community.
Why don't you use an automation rule for this?
I am exploring possibilities.  What is the benefit of automation other than simplicity of implementation?
anyway, the main question is if the script triggers automatically an event when i update an issue, or not
Register Now
