update grandchild in automation
Shani Levi July 30, 2024
hello,
I have this leveles in jira: HL Epic-> Feature-> Story
I trigger automation on HL Epic and need to update Story issue.
how can I do this?
Thanks Shani
Trudy Claspill
July 30, 2024
Hello @Shani Levi
When asking for help with an Automation Rule it will help us help you if you provide screen images showing the full automation rule, details of each step, and the details of the Rule Details page. If the rule is executing but not doing what you want/expect, then also provide the details from the Audit Log showing all the messages generated when the rule runs.
What exactly do you want to update in the Story?
Trudy Claspill
July 31, 2024
Hello @Shani Levi
Based on the image you provided for your current Automation rule, the flow you want is:
When a change is made to an HL Epic issue type
Then update a field in the grandchild issues (Story under Features that are under HL Epic)
Do you need some information from the Feature issues?
If not, then instead of using a For: Children branch I recommend you use a For: Related Issues: JQL branch. Using JQL you can directly retrieve the grandchild Story issues.
Like John Funk likes this
Shani Levi July 31, 2024
work good,
Trudy Claspill
July 31, 2024
You're welcome.
If my response has helped you solve your requirement, please consider clicking on the Accept Answer button to mark your Question as Solved.
hello,
this is my automation:
Thanks Shani
John Funk
July 31, 2024
Hi Shani - Welcome to the Atlassian Community!
I would create one rule to do the top level, and then a second rule to do the next level down.
