updating a Issue via advantage editing or curl
Christoph Schulz April 18, 2024
iam trying my best to update a "Team"/customfield but it seems i got stuck. i've found the id after entering it manualy, checking my issue. Is the field not ready for automation or iam doing something wrong ? when i click edit task it wont show up "Team".
The idea was to inform a Team about a new Task.
first i've tried advantage editing with
"customfield_10001": {
"id": "7de7cb79-2b59-4fd1-a3f7-6e99e2873180",
"name": "TestTeam",
"value": "option1"
next try was sending a curl request
curl -X PUT \ 'https://NAME.atlassian.net/rest/api/2/issue/OO-12' \ -H 'Authorization: Bearer TOKENNAME' \ -H 'Content-Type: application/json' \ -d '{"fields": {"customfield_10001": {"backgroundcolor": "#FF0000","name": "TestTeam"}}}'
Trudy Claspill
Hello @Christoph Schulz
What is the type of the custom field you are trying to edit? Is it a text field, a selection/dropdown field that allows only a single selection or multiple selections, a User Picker field, ...?
When you say "advantage" editing, do you mean the advanced JSON option available in the Edit Issue action in an Automation Rule?
