dear All
kindly i have jira 7.10.0 and confluence on same server
i want to upgrade to jira 8
is that ok
if yes what steps should i do to make sure
that server will run with no issue after upgrade
Hi @ahmed deraz
Depending upon the usage and the size of the server. It should be ok if instances are not huge already.
Upgrade Steps
https://confluence.atlassian.com/adminjiraserver080/upgrading-jira-server-manual-962958441.html
Upgrade notes
https://confluence.atlassian.com/jirasoftware/jira-software-8-0-x-upgrade-notes-957981660.html
As always test your upgrade on a separate test server first.
Ravi
