use a custom field for incoming email handler in jira
Blommetje
I need to use incoming email a lot for a larger website. This website is divided into Divisions. Each division has his own developer.
I have 1 emailadress for incoming issues. I would be great if the topic line could something like 'TV' and that the issue is automatically assigned to the 'TV' division developer.
I have 6 divisions, so it's needs to match with that. If it does not match, it should be assigned to the Project Admin.
Is this possible and where to begin? (the email handler works already, except for the divisions)
Blommetje
EDIT: Instead of a custom field for the divisions I can also use the Components. That might be easier..
Blommetje
Hi, thanks! It looks as this is only for the Download version. And I have the onDemand version.
Are there similar things for OnDemand?
Theinvisibleman
September 16, 2013
Hi there,
I think this might be able to help you achieve your requirements : JEMH For JIRA. The reason I said this is due to this documentation page for the plugin - Project mapping (group)
