Sign up Log in
use jql api to search for problems
Alejandro Yudis Amaya Bonilla March 17, 2022 edited
I need help I want to look for problems and that it shows me only the columns that I have decided but I can't find how I have my curl: curl --request GET \
--url '/rest/api/2/search?created+%3E%3D+2021-10-01+AND+created+%3C%3D+2021-12- 31+AND+project+%3D+LSD+AND+issuetype+in+%28%22Avianca+Sign+In+incident%22%2C+Incident%2C+%22Lifemiles.com+Incident%22%2C+%22Other+Services+Incident% 22%2C+%22PALM+Incidents%22%2C+%22QMS+Incidents%22%2C+%22Shopeo+incident%22%2C+%22iFly+Incident%22%29+AND+status+in+%28Closed%2C+Completed%2C+ Open%2C+Pending%2C+%22Work+in+Progress%22%29+AND+reporter+in+%285aa69c3cafb80a211be4bb71%29+ORDER+BY+created+ASC%2C+status+DESC%2C+updated+DESC' \
But it brings me a lot of data and many rows that I don't need, the only thing I need is
Issue key,Summary,assignee,report,status,severity,resolution,created,update,time to frist response
Capture.jpg loyaltyco.atlassian.net
Stefan Salzl
March 17, 2022
Hi @alejandro yudis amaya Bonilla
I had the same requirement some time ago and found jq to filter json response. Please see the following link:
https://stackoverflow.com/questions/62595453/filtering-from-json-output-from-curl-using-jq
Hope this helps.
Best
Stefan
Alejandro Yudis Amaya Bonilla March 21, 2022
I have achieved it with this code:
jq -r '["Issue key","Summary","Created Datetime","Severity","Resolution","Status"], (.issues[] | [.key,.fields.summary,.fields.created,.fields.customfield_11374.value,.fields.resolution.name,.fields.status.name])| @csv' <File.json>
Like Stefan Salzl likes this
Stefan Salzl
March 21, 2022
AWESOME!!! happy you could make it work 💪
If your issue is solved please consider to click "Accept" next to the answer so that this case gets marked solved.
Best
Stefan
Register Now
Upcoming Jira Events
