when I use the following in an excel cell, the task pane just says "1 of 1 rows imported. Saving..." and never actually brings back the query result.
=JIRA.JQL("issuekey=QI-695","summary")
I get a momentary #BUSY! message in the cell, then an "Import started at..." message in the cell. That's all.
I'm just trying to insert the Summary field value into the excel cell, not bring back a table or a property for multiple issues.
Edit: I tried this a different way, using a blank workbook and the following was the result, using 4 cells -- the cell I used the formula in, plus the 3 cells below it. This is not what is expected. Why would the 1st 3 rows come back from this usage? It seems poorly implemented if this is what was expected.
Import started at November 14, 2019 2:25 PM by Rob Wickham |
1 rows imported in 2 seconds |
Summary |
Risk management and customer requirements embedded within each process definition |
Has this been addressed? I’m also getting the 3 useless rows. Why isn’t the result placed in the same cell where the query is??
@Rob Wickham , just looking to clean up old issues. Is this stigma question for you or did you find the answer?
I stopped using it altogether because it didn't feel ready for prime time. Has the code improved in the last 2 years?
Found myself looking for an answer to this and arrived here - still seems to be the same, i.e. 3 additional/unwanted/useless rows output - what is the point of these?!
It's definitely been implemented with the expectation of returning a table of results, rather than a single field for a single entry. I see two ways to get round this...
I have the same problem , is there no way to only one value as output in a cell without the two other useless values ?
