×Hi,
A customer of my registered a Story with multiple sub-tasks.
Now they want to use a validator to enforce that running a review task is not done by the same user/assignee who ran the test report or development task.
On Jira Server a JMWE validator was used to check if other subtasks of the same parent where assigned to the current user, but on Jira Cloud "Issues returned by the following Groovy script" is not supported.
Does anyone have a solution/alternative on how to accomplish this on Jira Cloud?
Scriptrunner, JMWE and JSU are installed.
regards, Marco
Hi @Marco Brundel,
You can add the below Jira Expression in JMWE Build-your-own (scripted) Validator that returns true if all the sub-tasks of the current sub-task's parent, whose summary is "Ontwikkelen", are not assigned to the current user:
!issue.parent || issue.parent.subtasks.every(it => ((it.summary != "Ontwikkelen") || !it.assignee || (it.assignee.accountId != user.accountId)))
I hope this helps!
BTW, I'm from Appfire, the vendor of JMWE app. We have opened a support ticket SUPPORT-166845 in our support portal to better track your request and we added you as a reporter. If you need us to make any changes to the reporter field or unable to access the ticket, please let us know here in this thread.
Suprija | Appfire
Hi Marco,
I can confirm inside of ScriptRunner for Jira Cloud you can write a workflow validator to achieve your use case.
Workflow Validators use the JIra Expression Framework in Jira cloud provided by Atlassian, and we have some example expressions located here to show how these work.
Kristian
