what is JohnsonFilter in jira
Vedant Kulkarni
Nic Brough -Adaptavist-
July 29, 2019
It's a filter that uses libraries called "Johnson"
Vedant Kulkarni
This sounds like an appropriate answer because I don't have Johnson as a user in my instance but I saw this JohnsonFilter word many times in Jira Logs.
Thank you @Nic Brough -Adaptavist- .
August 2, 2019
Actually, no, it is not an appropriate answer, because I have written something that has made you look at the wrong thing.
"Johnson" is the name of libraries of code/data that you see when you question Jira sometimes.
It is not a user, person, or script, it's a library used by your server.
Alexey Matveev
July 29, 2019
It is a filter created by a user in the Jira instance, where you are logged in.
Register now
