i have a automation lately that is smoothly running
using this value on forms :
{{issue.properties."proforma.forms.i1".state.answers.1.choices}}
but when i check it today it always throws else value
foms do :
if question 1 answer is : yes it will marked as STANDARD change
if no open next question
if the question 2 answer : no it will maked as EMERGENCY change
if the question 3 says : yes it will marked as MAJOR change
else MINOR change
Hi Ramcel,
I have seen multiple posts that the functionality is no longer working as it has in the past. You should open a support ticket with Atlassian to find out what is going on with that.
https://support.atlassian.com/contact/#/
However, Atlassian has also implemented new functionality which is much simpler to use that what you have now. So you should be able to update your existing rules to use the new formatting.
See this article for guidance, and if it is helpful, please give it a Like.
Good luck!
