whats the difference between adding an individual user to a project role VS adding them to a group ?
sn
hi,
when i create a project and add users to project admin roles( individually) , they coudn't access some functions. but when i added them to a group "Project Admin" then they can access.
i'm new to admin and unable to understand by looking at our groups and schemes.
any input is appreciated.
thanks
Nic Brough -Adaptavist-
May 17, 2017
Users and groups in projects are only part of what you need to look at.
You need to cross-reference this with the permission scheme for the project.  This will say things like "project lead and role X can admin the project", "role Y can edit issues", "role Z can create issues", "everyone in group jira-developers can see the issues".
Once you understand that, you'll be able to look at who is in what role in the project to work out what rights they get.
Jobin Kuruvilla [Adaptavist]
May 17, 2017
Maybe the group is used directly in the permission schemes. Check your project's permission scheme to be sure.
Roles/Groups/Users can all be used in various schemes.
Josh Steckler
May 17, 2017
The way I like to use all of these pieces is to use mostly Project Roles (and the project lead) in Permission Schemes. I put groups as project role members on the appropriate projects. I set project role defaults so these are propagated to all new projects.
May 25, 2017
That is the recommended way for sure. But so many instances end up adding groups directly in schemes, sometimes due to valid use cases.
