when I select a group recipient, the columns sent to each user are different
Nour Durra _ Consultant June 9, 2016
This question is in reference to Atlassian Documentation: Receiving Search Results via Email
how can I send the same columns to all recipients in the email?
Andrea Carl
June 15, 2016
you will need to save the column order with the filter. Otherwise, it will just use the user's default columns.
Nour Durra _ Consultant June 15, 2016
Thanks Andrea for your reply.
How can i save the column order for a specific filter?
