when an issue is unassigned and transitioned in progress, then transition back to TO DO
Charu Pankaj kumar
September 20, 2024
 I want to do the automation When an issue is unassigned and transitioned in progress, then transition back to TO DO but no change when i test the rule
3 votes
Manon Soubies-Camy
Hi @Charu Pankaj kumar and welcome to Community!
I'd rather recommend adding a screen to the To Do > In Progress transition, with the Assignee field being required, this would be a better user experience. You can learn more here: How to prompt a required field when transitioning the status of an issue
But, to answer your question, can you please share a screenshot of your rule? This one should work as expected:
Hope this helps!
- Manon
