×I have seen the tips that "GitHub data can move to Jira directly coming soon" in the "import data" feature of Jira. I want to know when we will use this feature.
Hello @Peterzhu
Do you have a screenshot where you saw this.
Also for all of the upcoming features Atlassian has the roadmap: https://www.atlassian.com/roadmap/cloud?&search=github
There are some github features that were released in 2023.
Hi @Peterzhu
You can consider the below approach for importing GitHub issues to Jira
https://zmcddn.github.io/how-to-migrate-github-issues-to-jira.html
As of now, there is no such feature that is planned - https://www.atlassian.com/roadmap/cloud?selectedProduct=jsw&search=github
There are no
Hi @Peterzhu
I am Christophe a solution engineer for Exalate.
If you want to intigrate Jira and GitHub issues/PR's Exalate is the perfect solution for you.
With Exalate you can easily sync issues between Jira and GitHub.
To make your life easier you can create a trigger, this will automatically sync for you. So no more manual work.
The solution boasts a unique decentralized approach to integrate your work systems together while providing full autonomy to each side of the connection.
Exalate is easy and straightforward to set up and you can control exactly which data you want to send and/or receive.
If you would like to see a customized demo of the product, don't hesitate to book a slot with us.
Christophe De Beule
