would jira cluster.properties file accept jira.websudo.is.disabled = true
Isaac Montes
December 12, 2019
We would like to use the default atlassian AWS cloud formation template but trying to figure out how to define how to disable websudo for the nodes. I know is set in the jira-config.properties file. but OTB i don't think I can do anything with the template. Does anyone have an idea of another way to disable websudo without having to customize the playbook.
Earl McCutcheon
December 17, 2019
Hi @Isaac Montes ,
In Jira Datacenter you will want to set the websudo value in the jira-config.properties file in each node respectively in the Jira's local home directory, not the shared home directory.
As for modifying the launch to get this in from the start you would want to look at triggering a post launch startup script in the container as detailed in the following documentation, and use this script to edit or create the properties file and add in the desired configurations:
Earl
