I'm really curious about this but for all those who seek Atlassian Talent be it for:
My question is:
How do you typically hire:
Do you use an agency or do you try and hire directly yourselves?
Last question:
What issues/challenges have you found so far with the method you have chosen?
As a supplier of ClearHub for both contractors and FTE's globally, I'm curious to know if you, as a hiring manager, would have the same issue/challenges if you started to use an Atlassian Partner who specialises in providing Atlassian talent.
Solved! Go to Solution.
Thank you Theresa for your insight.
Yes, I believe for a number of environments that would be the same or similar for those who are both enabling and strategising a team/department.
My curiosity is more around when there is no option within the team and the company to call upon because the knowledge gap is too far and would take too long for what was needed.
Would you hire? If so would it be through your own procurement department? Would you utilise a support services contract through an Atlassian partner? Would you use a Recruitment Agency or would you go to a supplier who's specialises in distributing Atlassian contractors.
There is no wrong answer to this, I'm just trying to get an understanding what is more comfortable for those who have to make those decisions.
I had a terrible experience interviewing with an Atlassian partner. The process was unprofessional and dragged on for over a month, only to end with them canceling the role. I would recommend hiring a consultant directly to avoid the markup and have more control over the project.
I am no longer in a Manager role, but when I was I hired on a work management tools administrator as part of the PMO to support our Technical writers, Program Managers, Project Managers, and Scrum Masters in developing workflows, templates, automation, etc.
Thank you @Elizabeth Jones for your input on this topic.
So was this directly through the organisation or was it through a recruitment agency.
Either way, what was that journey like for you?
