Are there any solution for shift planning?
Musa Cuvarov March 27, 2022
I would like to plan our shifts, for further automatic assignment of daily tasks for employee\group on the shift in the process control project.
Are there any solutions for that?
Ste Wright
March 27, 2022
Hi @Musa Cuvarov
One option I can think of is using Automation - for example...
  • Trigger: Issue Created
  • Condition: If/Else Block...
    • Sub-Condition: createdDate is between these days/times
    • Action: Assign Issue
    • ...etc
...but this assumes shifts are relatively static, or you're willing to update the rule each time shift patterns change
The alternative is to find an App on the Marketplace
Do you think the automation option might work for you?
Ste
Hi Stephen,
Before the automation, I would like to plan the shift, let's say for a month, then every day responsible person might be used for auto-assigning to current daily tasks.
 I found similar functionality on the OpsGenie but it applied only to incidents as I understand.
Regards
Ste Wright
March 27, 2022
Hi @Musa Cuvarov
It probably works better if you're planning shifts a month in advance - but you'd need to work these into a set of If/Else rules in automation - eg.
  • If createdDate = Monday, assign to A
  • Else-if createdDate = Tuesday, assign to B
  • Else-if...
^ If you were looking for auto-assignment based on a calendar or users' listed work days, that's where you'd need to look at an App or integration.
I think you'd want something like this App, but it's not available for Cloud.
It might be possible do something with this App - Out of Office & Absence Automation - in terms of shifts?
Ste
Musa Cuvarov April 6, 2022
Hi @Ste Wright
unfortunately, your proposed solution is a bit hardcoded, and I'm searching for something like a schedule table with users in for a certain date.
Thanks.
