I'm exploring the options with Automation and while we do have the IF/Else block I don't think that we have something like a Case/Switch.
My use case would be a way to have a single field tested against several values but only execute the block of actions of the value found and not test anything else anymore.
In script this would mean you add a break in your case but nothing like that exists in Automation.
Anybody got some suggestions on how to mimic the behavior of a case where we can exit the actions block when the value is matched?
Hey @Dirk Ronsmans , just following up on this oldie-but-goodie:
There's an open feature suggestion for case blocks at JRACLOUD-74958 . Take a look and add your vote if this sounds like it would work for your use-case.
Daniel
Hey @Daniel Eads ,
Thanks for the feedback! Definitely looks like what I had in mind back then :)
Appreciate the followup!
