Custom field mandatory based on another field on create issue screen
nidhis July 8, 2016
I wish to make a field on JIRA create screen mandatory based on the selection of another select list field.
I have tried below two solutions:
def childField = getFieldByName("US Market Access")
def parentField = getFieldById(getFieldChanged())
def selectedOption = parentField.getValue() as String
if ((selectedOption == "Yes") || (selectedOption == "No"))
  childField.setRequired(true)
else
  childField.setRequired(false)
OR
FormField priField = getFieldById("16020")
FormField priJustField = getFieldById("15820")
String Criticality = (String) priField.getFormValue()
if (Criticality == "18170") { // 11306 is Blocker
priJustField.setRequired(false)
else{
priJustField.setRequired(true)
But both of them are making field mandatory, even if i dont select value of parent field.
i TRIED  "script runner" validator on create transition also "Has custom field value equal to "
that also made the same issue.
Can you please suggest the script to use?
refrence help:
https://answers.atlassian.com/questions/267139/can-we-set-a-custom-field-as-mandatory-based-on-other-custom-field-value
Nidhi
Thanos Batagiannis [Adaptavist]
July 8, 2016
Hi Nidhi,
If you want a behaviour try the following
def selectCFValue = getFieldByName("Single Select List CF").getValue()
def targetField = getFieldByName("US Market Access")
if (selectCFValue == "OptionA" || selectCFValue == "OptionB")
    targetField.setRequired(true)
else
    targetField.setRequired(false)
regards
Thanos
nidhis July 10, 2016
Thanks for that,
When I try it in the create transition of the workflow, its showing Field mandatory error even if I do not select any value in source instance:
def selectCFValue = getFieldByName("Impact Transaction Reporting").getValue()
if (selectCFValue == "Yes" || selectCFValue == "No")
else
July 20, 2016
hi nidhi
I am a bit confused. Do you want a validator or a behaviour (the example above is a behaviour) ?
roniz
hi -Thanos Batagiannis I also have a question regarding this issue-
field A is a select list- single choice.
I want to create a configuration on the "create" screen-
if field A='x' --> I want to make field B mandatory.
Can you help me please?
Thanks!!
Like fobrutsky likes this
Nadica Gaber
Hi All,
The behavior script posted above:
else
It works witch select lists. However if the source field is Tempo account filed it does not recognize neither the value or the ID of the account. Do you know the correct method to get the value for Tempo account Field?
Dan27
Hi @Nadica Gaber ,
I used your code on behaviour to the same issue.
I would like to make 'environment platform' field (Text Field type) a mandatory field, only if 'Patch type' field (Select List (single choice) type) = 'X'.
There is something I should choose or select in the behaviour settings? cause it didn't work for me..
This is my code:
def selectCFValue = getFieldByName("Patch Type")
def targetField = getFieldByName("Environment/ Platform")
if (selectCFValue.getValue() == "GA Point Patch" || selectCFValue.getValue() == "GA Cumulative Patch")
else
and attached the behaviour screen:
Nadica Gaber
Hi @Dan27,
You are missing getting of the value from Patch Type field.
Add  getValue():
def selectCFValue = getFieldByName("Patch Type").getValue()
Nadica
Dan27
Hi @Nadica Gaber ,
Still not working...
my new code:
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
def regressionIssueField = getFieldById(getFieldChanged())
def selectCFValue = getFieldByName("Patch Type").getValue();
if (selectCFValue == "GA Point Patch" || selectCFValue == "GA Cumulative Patch") {
} else {
