I need to use the Cumulative Flow Chart but currently this can only be used to display data for 1 project at a time. My Kanban board uses a query that combines 5 different projects. Is there a way for me to use a query with the cumulative flow chart? Or any other way to display data for multiple projects on one cumulative flow chart?
Hi Charles,
The cumulative flow chart in the new boards will show all of your projects, it is not project sensitive.
Shaun
Thanks Shawn, I was using the chart widget instead of the one for the board. My bad. Thanks so much for pointing this out to me.
