Same Trigger issues
ERIK GAUDIN
We are also struggle to make this work :
  • A ticket is create in a JIRA project (From a Form)
  • An automation copy that Ticket when created, to another JIRA project (each field synch), and like them
  • On the destination projetc, we have an automation that are suppose to be trigged on ticket creation.. but it's not trigger when the ticket create from the previous automation. I also try the tick to use a lable.. and hope the other rules trigger on this LABEL.. same.. this Automation does nothing.. unless the ticket is manually created in that project
So.. i'm trying to find how i can tell an automated task to start another automated task. It seem the new ticket are created so fast, the other task can't see it... or all Automated task start all at the same moment.. that made one not seen what the other did.
John Funk
April 5, 2024
Hi Erik,
Make sure the box for "Check to allow other rule actions to trigger this rule. Only enable this if you need this rule to execute in response to another rule." is checked on the second rule that is not getting triggered. Refresh and try again.
