In this video tutorial we share how you can create a Jira Dashboard in 3 simple Steps:
Most gadgets in Jira require a saved filter to display the information. You can use the basic search or advanced search to create the filters. You can find more information on how to create filters here.
This is the easy part, just go to the "Dashboards" menu and create a new dashboard.
Once you have the dashboard created, add the gadgets. Here is the full list of gadgets that can be used out of the box.
Make sure that the permissions to the filters and the dashboard are set properly or your colleagues/clients won't be able to access the beautiful dashboards you have created.
Fabian
Fabian Lim
Consultant
N/A
Toronto
564 accepted answers
9 comments
