×I'm just starting with JIRA, and I'm looking for tips on how to organize the work.
Think of this pretty typical situation:
Should we have a single project, and several boards to reflect teams, components, etc?
Or should we have several projects, and boards that combine projects as needed?
By the way, is there the concept of "team"? Can we assign a task/epic to a team?
Thanks it helps.
Regarding my "team" comments, is there a workaround?
My idea is that, when a team will work on organizing its backlog, or its sprint, how will they know what's relevant for them among all the noise of the other teams?
for this case
You can create a regular scrum board.
If you have 3 teams, you can configure 3 different scrum Boards.
Create 3 groups for 3 teams. and add users as per team structures.
Now configure each scrum board filter with view access to "Respective New group".
So only team members can view their respective board only. so it may not big mess in the backlog or sprint items.
Please try with a dummy project, I hope it may helps.
I think there is a misunderstanding. Is the "backlog" specific to a board?
What I meant is, where i CREATE a new issue - how do I specify which group it is relevant for? So that when they plan their sprint, they'll know what to look for?
all issues in the Backlog & Active sprint are displayed based on the Board filter.
I've one more suggestion
Create a Custom Field with dropdown (Single Select)
Example
Field Name (Team) -- Values (Team A, Team B, Team C).
Now create 3 new scrum boards configure Board filters as below
Team A Board Filter --> Project = ABC and Team = Team A.
Team B Board Filter --> Project = ABC and Team = Team B.
Team C Board Filter --> Project = ABC and Team = Team C.
when you create new issues -- Please choose Team A / Team B/ Team C.
So based on the team Values issues will be shown on different boards.
So every team can only able to see all the issues related to theirs. you can select multiple componnets.
adding to the great information you already have received I am wondering if a custom field of type "user picker (multiple)" or "group picker (single or multiple)" could address the need for reflecting that several people are working on an issue.
It is not specifically an Assignee-field as 1 issue = 1 assignee in Jira but doint it that way it can help improving visibility. You also can use the field in Permission Schemes (assigned to a project) and/or Notification Schemes.
For hiding/unclutter comments from one Team (comments that are only meant for another) there is no neat solution as per date - on Jira Server there was an option to restrict comments for roles/groups - but I felt in daily use this is a bit cumbersome. On Jira cloud I could not find that option either - I think it was never introduced on Jira Cloud (or I could not locate it).
For the very valid core of your questions I found that there are several discussions in Community around it, probably it is worth reviewing them also for some inspiration.
Finally, some discussions around the topic:
https://community.atlassian.com/t5/Jira-questions/Multiple-teams-and-a-single-project-or-multiple-projects/qaq-p/1666501
https://community.atlassian.com/t5/Jira-questions/Multiple-Boards-or-Multiple-Projects/qaq-p/1271310
Daniel
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Get the most out of Jira
Explore the interface and basic Jira terms, then discover how to effectively manage your work.
Learning Path
Atlassian tools and practices for developers
Focus on your development work by using Jira software features and functions efficiently.
Atlassian Certified Associate
Jira Software Essentials certification
Demonstrate proficiency in utilizing essential Jira features and working efficiently with Agile frameworks like Kanban and Scrum.
